PC-W
Using industrial embedded platform, the system is stable and reliable, it has rich interface. Wireless communication GPS navigation, fault detection, video capture and other functions, can be extended to provide users with a powerful mobile multimedia information system.
  • powerful 1.86GHz dual-core CPU,2G DDR3 RAM
  • 10.4″ LED display with resistive touch
  • RS232X4,COM 2 supports RS485/232/422
  • 3G/WIFI/Bluetooth/GPS for optional
  • Wide voltage 6-32V for optional
  • Metal housing design
  • Fanless cooling system
  • HDMI&VGA output
  • Dual Ethernet port
  • Multiple mount methods
$580.00
Part number: PC-W Category:
PC-W Embedded Control System
The PC-W Embedded Control System is built on a robust industrial embedded platform designed for stability, reliability, and high performance. With rich interfaces and advanced communication capabilities, it delivers exceptional functionality for demanding industrial and mobile environments.
This system integrates wireless communication, GPS navigation, fault detection, and video capture, making it an ideal solution for powerful mobile multimedia information systems.
Key Features & Highlights
  • High-Performance Processing: Equipped with a powerful 1.86GHz dual-core CPU and 2GB DDR3 RAM for smooth, efficient operation.
  • Clear 10.4″ Display: Features a 10.4-inch LED display with a resistive touch screen, ensuring easy control and visibility.
  • Rich Interface Options:
    • RS232 × 4
    • COM 2 supporting RS485/232/422
    • HDMI & VGA output
    • Dual Ethernet ports
  • Advanced Connectivity: Optional 3G, WiFi, Bluetooth, and GPS for seamless communication and navigation.
  • Flexible Power Supply: Supports wide voltage input from 6–32V, suitable for various industrial applications.
  • Durable Construction: Features a strong metal housing and a fanless cooling system for long-term industrial reliability.
  • Multiple Mounting Options: Designed to fit different installation environments with versatile mounting methods.
Applications
The PC-W Embedded Control System is ideal for:
  • Industrial automation
  • Vehicle-mounted systems
  • Intelligent transportation
  • Mobile multimedia platforms
  • Monitoring and control applications
  • Navigation and communication terminals
Why Choose the PC-W Embedded Control System?
With its powerful processing, rich I/O ports, wide voltage support, and advanced communication features, the PC-W provides users with a stable, reliable, and expandable solution. Its ability to integrate multimedia, GPS, and wireless communication makes it perfect for modern industrial and mobile environments seeking high performance and durability.
Structure graphic:
PC-W
Weight 2.19 kg
