Relay I/O Modules
The “Plug-in” I/O Module series provide general purpose interfacing for DDC and industrial automation systems. The modules plug into industry standard termination boards and provide optical isolation between the controller and field devices. Color coding identifies modules at a glance.
  • Plug in mounting arrangement speeds installation and testing.
  • 4,000V Optical Isolation Input to Output
  • 5A output modules for most pilot duty applications.
  • 10A output version with heat sink for larger loads
  • DC and AC input modules, custom versions available
$5.50
Stock : 50 in stock
Part number: OAC5 Category:
Relay I/O Modules
Opto22 style, plugable output relay module, 5 Amp, 220VAC
Weight 0.10 kg
