T3E-Nano Programmable Router
The new ESP32-POE board is a Wi-Fi-enabled development board based on the ESP32
  • Sturdy construction, consistently gets good comments from our clients.
  • UL listed ABS enclosure with rubberized texture creates a high end feel
  • Connect over Ethernet,RS485
  • Supports Modbus and Bacnet protocols simultaneously.
  • Starter space source code is avaliable
  • T3000 front end is free and open source: http://tinyurl.com/n7kkqp6
  • Compiled version of the front end is here: https://tinyurl.com/y7uyu9n3
$61.00$62.50
The T3E-Nano Programmable Router is a versatile programmable controller that supports both Modbus and BACnet protocols simultaneously. It features an isolated power supply and opto-isolated communication, ensuring reliable and secure operation for industrial automation.
T300 Bacnet Programmable Controller Series
Programmable controller for industrial automation
Dimension of programmable controller industrial automation device
These devices support routing over Ethernet, Wifi and RS485 over both the Modbus and Bacnet protocols. There is no limit to the number of points which can be routed through them. While the router passes common objects transparently, we can add additional features if your use case requires more complex routing. Therefore, please send us an email to discuss your requirements.
Modbus BACnet router Ethernet WiFi RS485 unlimited points transparent routing
Connect to the network via POE
In conclusion, the T3E-Nano Programmable Router is a highly versatile and reliable solution for modern industrial automation. This programmable router supports Modbus and BACnet, compatible with many devices and systems. Additionally, it features an isolated power supply and opto-isolated communication, ensuring safe and stable operation.
With the ability to route data over Ethernet, WiFi, and RS485, and no limit to the number of points that can be managed, the T3E-Nano Programmable Router offers unparalleled flexibility. The router passes common objects transparently and allows you to integrate additional features for more complex routing requirements. Overall, it provides a scalable, secure, and efficient solution for all your industrial automation needs.
Model
DIN Rail, ESP32, No DIN Rail
