Tank Level Sensor
  • Simple device for measuring tank level in many building automation applications.
  • Sturdy construction suitable for harsh automotive and marine use.
  • Reed switches provide a stable 0-10k ohm resistance signal proportional to the tank level
  • SUS 304 Stainless Steel for compatibility with fuels, water and most process chemicals
  • Economical level sensing solution, simple installation and long service lifespan.
  • Length can be customized, contact us for details
  • Includes O-ring for easy for installation on standard SAE 5 hole pattern
  • O-ring material:Nitrile Butadiene Rubber
  • Operating Medium:‌ Diesel, Gasoline, Lubricating Oil, Water
$25.00 - $49.00
Part number: TL-150 Category:
The  Tank level sensors output a continuous 0-10k Ohm resistance as the float position changes. As the float rises and falls, one of 10 dry contacts close and engage one of several resistors inside the unit. There are no active electronics in this device, just dry contacts and resistors which means there are fewer parts to fail.
No power supply is required either, just wire the two conductors into any input on our T3 controllers and expansion modules and set up a custom table to match the height of your sensor and tank.
All metal parts are 304 stainless steel for compatibility with fuels, water and most process chemicals. Mounting is done through hole with 5 bolts to secure the sensor and a flange to seal the opening.
Wiring Diagram:Wiring Diagram of Tank Level SensorDimensions:
Dimensions of Tank Level Sensor
Part number scheme of Tank Level Sensor
Resistance versus Position
Resistance versus position of Tank Level Sensor
Note:
We can customize this product in various lengths and flange fittings. Drop us an email if you have an application in mind.
This tank level sensor provides a reliable, maintenance-friendly solution with its simple dry-contact design. It eliminates the need for external power or complex electronics, ensuring long-term durability and ease of use. Built with durable 304 stainless steel, it ensures long-term performance across fuels, water, and various process chemicals. Easy to install and compatible with T3 controllers, it provides accurate level monitoring for various industrial applications.
Weight 1 kg
length
150mm, 500mm, 950mm, 275mm
