USB to RS485 Converter
The USB to RS485 Converter transmits smaller data blocks over long distances while multiple nodes share a two-wire bus.
  • RX and TX LEDs speeds up debugging, shows all communications activity.
  • Ground Loop LED lights up when any of the nodes has 24VAC and GND crossed over.
  • Self resetting fuses protect the PC from wiring mistakes in the field.
  • Uses standard FTDI chip(FT232RL) and windows drivers for any protocol and any baud rate.
  • Low cost converters, cheap enough to install & leave everywhere you might need them.
  • USB powered, no separate power supply required.
  • Three pin terminal for connecting to network cables
  • Auxiliary jack for connecting to RJ style jacks on the bottom of many items on this site: Tstat8, HUM-R and AQ-1.
$12.00
90 in stock
Part number: USB-RS485 Category:
This device is one of the lowest cost units on the market yet has some features that make it stand out, specifically the three status LEDs which show incoming and outgoing data activity. A yellow Error LED indicates wiring faults in the network. It lights up when nodes have reversed 24VAC polarity.
Sharing a transformer across devices is common in building automation, making consistent 24VAC difficult. The LED quickly identifies issues, simplifying troubleshooting and debugging.
USB to RS485 Converter dimensions showing length, width, and height
RS485 is a multi-drop network, it can connect Tstat and controller, perfectly transferring and receiving the data. The devices can be up to 254.
USB to RS485 Converter wiring diagram showing RS485 A/B connections
Overall, this USB to RS485 Converter delivers an excellent balance of affordability, reliability, and practical diagnostics. Status LEDs clearly show data activity in real time. Error indicator quickly identifies wiring issues for easy troubleshooting. A cost-effective solution that saves time during installation. A smart, dependable choice for long-term maintenance.
Weight 0.08 kg
USB-RS485-N
10.9
