The MR Mechanical Relay is a general purpose relay suitable for both low voltage and power switching. It features a low power coil, the 12VDC version requires only 100ma to energize. The DPDT relay is rated at 10A, 120VAC. Each relay has an LED showing the low voltage status.
- Mechanical lifetime of 10^8 operations
- Switch low and high level loads from 100 mA to 7 A
- Pluggable base is panel mount or din rail
- Handy status LED shows the coil status
- UL recognized, file No.: E169380
$4.00 - $4.50
| Weight | 0.20 kg |
| Coil voltage | 120VAC, 12VDC, 220VAC, 24VAC |
